clutch slave cylinder
Just done this on mine, I think it's about 7mm piece of rod just cut longer and rounded the ends off
Make a new one if you don't have enough clutch clearance ...
or shorten it if biting point is wrong but fully adjusted on the peddle
my padal is maxed out ... can`t extend it any more and can`t get in to 1st gear while moving even 1mm per hour :) and i need to force from first to second gear. so don`t know how much i need to extend it :) btw it`s a brand new clutch
Wind the Adjusting nut all the way back .. and make a new Rod around 1/2" Longer and then try again
make from what ? :)
Rolandas...iff you get a precise size (length/thickness) you need ile knock you one up on the lathe mate:wink:
