Light question
i have sometime ago have taken my front bumper of and bined it along with the front indicators and lights holders in the bumper. My question is how do i wire the front plugs up that are there with the origanal three pin connecter plug so my indicaters dont flash two fast. when on hazard they work fine but when on indicatoe there to quick. thanks guys.
A cheap fix is to wire another "hidden" bulb and use this as a slave
thats a top tip . it always seems to be the easiest option that we dont think of. have some rep
Brian's idea is practically free but the way to go is order a fast flash relay for a few pounds and then fit whichever bulbs you like in the indicators.
And if you want to do away with your filament stock stop/tail bulbs just pull out your warning bulb from the clocks or black it out.
what ive done will be clear soon i have got rid of the front bumper indicators and used the side indicators for the front by moving them to the front of the wing and dont need the front ones so ill try the resistors tom
like we said (me and phutumsch) you are much better off with a new indicator relay unit... simple job and good for further changes...
