what mods are what stage??
as it says, is there any "standard" for what stage your car is for the mods done, or do you just make it up?? ;)
I've got a pdf file from Stillen that lists them all but can't find anywhere to upload it at the moment.
HKS DO THERE OWN AGENDA.
General rule of thumb though is to use
SGP stage chart
90-96 Nissan 300zx-TT
Staged Upgrades
Stage 0
Stock 280-300HP
STAGE I
JWT POP Charger/Underdrive Pulley
305-325HP@10PSI
Improved Low End Response
STAGE II
JWT ECU Upgrade
365-380HP@12-14PSI
Removes Limiters/Expands Fuel, Timing,
and Boost Maps/Increases Boost
STAGE III
B&B Test Pipes/Gut Pre-Cats
385-400HP@12-14PSI
This Upgrade Will Shock You!
STAGE IV
Cat Back Exhaust
400-415HP@12-14PSI
No Exhaust Restriction/Great Boost Response-Car Pulls Hard
STAGE V
Boost Controller
420-435HP@15PSI
Steady Boost Response;Control/Solid 15PSI Of Boost
STAGE VI
JWT NOS System
490-505HP@15PSI
Car Shoots Out Of The Hole/System Engaged Until 10PSI
STAGE VII
Intercoolers
495-510HP@15PSI
A Must Have For Future Upgrades/Increased Cooling Efficiency
STAGE VIII
JWT Twin POP
510-525HP@15PSI
No Intake Resrtiction/Turbos Will Sing
STAGE IX
Ported Trottle Bodies/Mached Intake
515-530HP@15PSI
Car Now Ready For Injector/Turbo Upgrade
STAGE X
NISMO 555cc Injectors
530-545HP@17PSI
Now Able To Increase Boost/Upgrade Turbos
STAGE XI
Sport 500 Turbos
555-575HP@17-21PSI
Sport 600 Turbos
560-605HP@17-21PSI
Sport 650 Turbos
(Cam Upgrade Required)
620-675HP@17-21PSI
STAGE XII
JWT Cams/SGP Head Package
640-695HP@17-21PSI
Warren - stage XI suggests its ok to run it at 17-21psi ? They have to be joking, are they into selling replacement engines then?
Providing the fuelling is correct all throughout the rev range, higher boost levels are okay, running 17-18psi meself using bigger turbo's and other mods.
Oh and why is there no mention of fitting Cybercarfts shiny bits and bobs to increase the level, not fair :D :D
smithy:cool:
Well with any luck ill be running 20psi now its all done, just so long as its all done correctly.
Will have to wait and see how long before Boom lmao again.
so have you lot who run at high boost levels got NOS fitted?
Nope. Although I had 555 injectors and JWT turbos when I ran it at 20+psi ..... bang went the engine! I won't be doing that again.
