Best Front Camber Arms?
So I like the look of the SPL Pro range of adjustable suspension arms
ย
However....
...they don't do front camber arms.
ย
There are other manufacturer options, but what are good quality front camber arms, that will last?
I think SPL are currently redesigning their front camber arms. With SPL not available I would go Powertrix
cyberspeeds are very good and nice quality.Lee
ย
ย
spl havent made 300zx ones to my knowledge
ย
the ones to go for are the more expensive z1 motorsport ones
ย
ive heard of a few powetrix failures in the states unless they have done a revised version
Z1 have designed their own FUCA's that I have been looking at...
they are the best ones on the market at the min but unless you run rose joints every where else already on the front you need to order the poly version else the rose joint versions bearings will go as it puts to muche pressure on them with out the rest being done
They definatly used to, but they took them down and put a notice up saying they were revising them. But now even the notice is gone, so not sure whats happening there.
ย
Thanks for the recommendations guys.
Those Z1 ones look good. The rose joint ones should survive with rose joint tension rods only?
How will the SPL Pro solid Tension Rods hold up if I get the poly upper arms?
