Front indicators not working
Hi all,
I have just put a aftermarket front bumper on and now the indicators don't work. I had to take off the bar behind that the fogs are attached to which had a wire with a block on the end of it, I have attached that to the plastic under guard. That is the only wire I have moved as far as I know.
Anyone got any ideas?
James
The wire u moved sounds like temperature sensor for inside the car..
U must have disturbed somthing why u was down there, to stop indicators working.
The only thing u can do is pull the lights back out and inspect all the wiring...
Cheers mate, I was wondering what that wire was. Will have a good look at the wires tomorrow.
Is it just the front indicators not working are are the rears not working as well? if it all of them failed it maybe just a coincidence they are not working try wiggling the hazard switch this can sometimes be the cause all of the indicators not working as the switch has not returned to the off position.
Jeff TT
Hi Jeff,
It's just the front front indicators that are not working, the side repeaters work as well, just the ones on the front bumper.
