April 7, 201313 yr Hi, Can anyone tell me if the headlight wiring is part of the main engine loom (with the fuse box etc), or is it this one - http://www.ebay.co.uk/itm/330894538614?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 There is also a harness that goes over the inner wing, but it doesn't seem to be that one as far as I can tell. I will at some point will need to replace the harness that goes from the pod to the headlights, either that or mess around with wiring. I was looking at the wiring on my shell, but couldn't work out where it was going, not without removing it. If anyone knows I'd be most grateful! :)
April 7, 201313 yr you got a job on there mate almost positive that the headlight are on the main fusebox loom
April 7, 201313 yr Author you got a job on there mate almost positive that the headlight are on the main fusebox loom It depends on which link you looked at, the more recent is - https://www.facebook.com/media/set/?...1&l=1c32d0655b I too have a bad feeling that the headlights are on the main loom / harness...
Hi,
