under side of bonnet cleaning
When i got my zed 8 years ago the under bonnet insulation was missing its now very dirty tried a few cleaners and it wont shift the grime has anyone got any ideas how to clean it .Think im gona have to take it of to clean thanks taff .
Put a tarpaulin over the engine and pressure wash it !
Go with the tarp - and then coat the underside of the bonnet is something like Gunk, leave to soak for a few minutes, then hose down!
Otherwise parafin or methylated spirits should also help dissolve grease and grime!
Do you have access to a steam cleaner?
TFR is good for this, wear gloves and use a cloth for accuracy, or as said, cover engine and just spray a layer on, agitate with a brush and then rinse. :)
Be aware though!!!!
TFR will mark non metallics, hence the suggestion of local application with a cloth ;)
Otherwise make sure panels are covered or soaked with soapy water :)
Do you want an under bonnet insulation sheet lol, cover it up :lol:
