idiot lamp warnings
Hi,
everytime i press the brake pedal i get "light" fash up on the dash, checked all bulbs all working fine, is this a warning to let you know a bulb is out? if so all my bulbs are working properly?. also Anti-lock light comes on randomly, would that be a dirty sensor? if so where abouts are they located? on the caliper? can they be cleaned? or would it be the ABS relay playing up?
Thanks in advance
leeroy
no, standard bulbs
had the same issue, all bulbs working, but when you put your foot on the brake pedal, light lit on dash. easiest solution? take the damn warning bulb out.
ill think ill just do that, wonder if it would come under M.O.T failure?
Nope, mine just sailed through, not even an advisory.
Could be low brake fluid.
wasnt on mine, i checked all that when i got the car at Richards house. it was doing it with me from when i brought the car, that was also when i checked the bulbs. but worth checking anyway.
As already mention could very well be the 'Bulb Check' unit, it's located (if my memory serves me well!) on the righthand rear light unit (or there abouts).
But I'd defo be checking the fluid level for sure, as this is a good potential point.
Dave
