Back from SilverSurfer with his old Z, I was going to take what I needed for mine and get rid. Now it seems mine might be the casualty and keep this one instead after swapping over my goodies! Pictures soon as on iPad but the is one on the http://www.facebook.com/sfshoses !
look forward to the pics mate...get the spanners out:cool3:
  • 1 month later...
Massive thanks to Mr Derby who rescued me from the gearbox nightmare. Ready to start as soon as the ecu arrives which should be tomorrow. Also wheels should be here as well, will add more pics later this week as lots more done already!
Latest news is she lives, got loads done today, brake lines, clutch line, arch liners and exhaust all on and she runs! Pics soon
Cheeky few hours work today, bled brake and clutch lines, remove rear hicas and fitted lockout bar. Original hicas rack bolts were a nightmare and put up a good fight!
Putting all the bits back on to makes sure it all goes together properly before painting, cut out rotten cill ready for welding
Made more progress in the few hours I've had although doesn't look much!
All the lights and wiring fixed, rear strut brace fitted, one rear hub changed, brakes bled, longer clutch slave cylinder pin fitted, p/s bled and now moves under its own steam and stops!
Fitted the rear spoiler, carbon from a car I'm sure you all know! Car will be white so what does everyone think of it?
Looks like its going to be a cracker when it's done
When are you planning to have it sprayed?
Next week!
Thoughts guys? Going white with carbon rear spoiler, carbon Gtr bonnet vents and carbon scuttles and carbon look vinyl all the trims around the screen/roof etc.
Should I do the roof black or go all white? If anyone fancies photoshopping it white :yes:.....
Progressed a bit more tonight, all the bits fitted, side skirts, new clutch pin works a treat, handbrake now exists along with decent brakes !
Now looking sorry for its self as I've just stripped t again ready for paint !
I would stick with targas I reckon
This is a swb slicktop in white but would take a lot of fabrication to get that look
This is another idea to bear in mind which you could do with the targa top but I think I prefer the colour separation between the targas and front/rear glass
White will be very nice, arctic/ice white is lovely on a ZED. You could get it all painted white and vinyl wrap between the Targa's in carbon or black. I personally think that this would look good and if you don't like it, remove it! Bingo, job done.
Well one cill has been welded and started to be filled but the other side isn't great. The rot is much worse than we thought so she may not make Japfest due to the time needed to weld so many bits :-(
At least it'll all be cut out and done properly and with no winter driving and very little wet weather it will last a long time
