As you can imagine since my turbos parted ways with there seal, ive been looking in the rear view mirror for smoke as much as the road infront waiting to see what happens. early reports were good did a few 5 mile round trips etc, at first there was a fair bit of smoke but then it died down, eventually the last few of those small journey's nothing. Which I was very happy with, yesterday I took it for a blat up the dual carriage way and back to see what it did again pulling well no smoke etc etc.
So today I took it for a proper drive, I drove it for about 2/2.5 hours covering about 80 miles of mixed driving and full throttle acceleration through several gears. So really todays the first time its got hot, properly warm. the first hour was all smiles and very much the same smoke free-ness as previously, but about an hour or 2in I started to get smoke again, not the same as before mind. Previously I had grey/blue smoke at low rev pull away and idle, uptil 3k when it cleared. This time Im literally only getting it on the overrun. which is intermittent, it DONT get plumes of grey everytime I downshift and engine brake, its only every now and again. Its also worse in traffic for example at 30mph on the overrun is worse than at 70.
The negative side of me is saying great the piston rings are on the way out, and that is now a new problem after ive just pulled the damn engine. The positive side of me is saying the following, you did a compression test pre turbo refurb, which came back very healthy, between 165/170 on all cylinders. The car has done around 100 miles since all that oil ended up in the exhaust, and this is the first time that exhaust has got upto full temperature. So im reasoning with myself, that its merely oil residue burning off still and the hot gases aren't passing through as fast so im seeing the smoke burning off like that.
I do have a habbit of being very paranoid and the reasoning strange things with myself.
Opinions please??????????
