caliper paint
i have r32 breaks on my zed and they are in need of a refurb badly has anyone got a good idea which caliper paint is the best for the job
I just used hammeririte on mine, did the job nicely :)
nice1 i'll google it now, wat u reckon with dark blue. i was thinking gold for some silly reason i ust 2like the clio williams!
I used 2k when it actually sets and don't react like in my engine bay lol, it's rock hard and should handle heat
i'm going for hammerite gold, what is a better finish spray can or outer the tin
Yeah, rattle tin will give you a better finish. Give it plenty of coats, with a decent amount of drying time.
Did mine. Rub em down, primer them with red hammer ute primer then red hammerite spray and bake in a normal oven for an hour and leave to dry over night, the paint should go hard. Hammerite takes ages to harden without some heat.
See finish product below ;)
Hammerite does melt when you get brake fluid on it tho, as I found out, just be careful when bleeding.
mr google said the same about hammerite, when ive being reading about the name halfords enamel paint keeps popping up so that could be a possibility
Folia Tec makes paint specifically for brake calipers - I'm sure you can source it over the interweb.......
.....or of you fancy spending more than you need to, buy it from Demon Tweeks!!
Richard:cool3:
You just pore water over the calipers if you get brake fluid on them.
