Removed the fuel pump today to insert fuel foam to try and baffle the fuel a bit.
I noticed in the tank is a square shaped kindof baffle with a hole in the rear at the bottom of it and a slight cut off at the top of the front.
So the baffle fills up under breaking and empties during hard acceleration. Is this ideal?
The baffle is made of plastic so I cut a small section out at the front to allow fuel to fill during acceleration. Maybe i should have made some cut outs on the sides aswell to prevent starvation during Cornering?!?
