Engine Build Take 2 Plus CPZ Order
Been saving up for my next engine upgrade
Going to be Proper Power now :)
Emerald After Market ECU ( Got )
90mm Wiseco pistons $750
90mm Cometic HG $166
JWT 500's Cams $920
BDE VTC Pulley $445
BDE EX Pulley $365
2.5" inter cooler pipe set *
Side Mount Inter cooler's * $1500
Larger throttle body's *
Clear timing belt covers $195
Surcharge $150
Postal $245
Total $4736 = £2928.69 A fooking lot
plus import duty's
Plus another £200 quid for Engine work
Is any other person needing items from cpz in a few weeks time ?
Edited by MarkDerby
  • Replies 298
  • Views 13k
yeah ... need to do the external thou the water holes i have internal gauge its just to see how thick the bore walls are before ordering the pistons ..
Your determined to go 89mm arent you,all that aggro and for what little power it will yield,id stick with 88mm, but if you want it i can post it up,if your boring the block it wont be necessary,however if your re ringing and want to check the bores are good before honing you will need it.
Well thats all my Parts Ordered
Intercooler Pipes Ash 2.5 black t-clamp $475.00
rs performance large Intercoolers $625.00
Throttle bodys Rev2 Chrome $400.00
AMS Cam Covers clear $175.00
JWT 500 Cams $920.00
JWT 300ZX Heavy Duty Valve Spring Set $312.00
BDE VTC Pulleys $445.00
BDE Exh pulleys $365.00
89 mm Wiseco pistons $575.00
89 mm 053 Cometic gasket $150.00
Upgraded Heavy Duty Clutch Fork Kit w/ Fork Boot $72.50
AEM 30-2998 300ZX ECU Extension Patch Harness Z32 $155.00
Alloy Toyz 300ZX 3in SS Expansion Downpipes - 5-Bolt $295.00
Fan & Shroud Kit $164.50
Surcharge $150.00
Postal $345.00
Garrett 300ZX GTX2863R $3,063.00
Total Cost $8,687.00 :hang:
Gulp, that's some list Mark.............and price ........:whistling:
Should be a monster when finished matey
i still got $150 to come back of that order Providing i can send the cam gears back cheap
WOW nice bag of bits there...just need a good engine builder now:nelson::D
cheeky fook lol
Ouch that's alot of money! Are you going ahead with cryo treatment?
yeah i got the price better at frozon solid .. £250 all in
have to get the Main work done on the block IE Rebore up to 89mm and Head decked
then off to get treated then back to machine shop to have it Honed/polished/acid/cleaned
yes ... and having the bolts tig'd
had my injectors tested .. and there all spot on
well Preformed a little better than spec
Edited by MarkDerby
  • 3 weeks later...
Can not wait to get home .. My CPz Order as just landed Sent on the 21st on my door 26th very quick turn around .. 4 big boxs of stuff :) :bow:
Make sure you post up pictures Mark, you know we're all addicted at looking at engine/shiney parts, lol
What he said^^^^
