Engine Build Take 2 Plus CPZ Order
Been saving up for my next engine upgrade
Going to be Proper Power now :)
Emerald After Market ECU ( Got )
90mm Wiseco pistons $750
90mm Cometic HG $166
JWT 500's Cams $920
BDE VTC Pulley $445
BDE EX Pulley $365
2.5" inter cooler pipe set *
Side Mount Inter cooler's * $1500
Larger throttle body's *
Clear timing belt covers $195
Surcharge $150
Postal $245
Total $4736 = £2928.69 A fooking lot
plus import duty's
Plus another £200 quid for Engine work
Is any other person needing items from cpz in a few weeks time ?
Edited by MarkDerby
  • Replies 298
  • Views 14.6k
Nice Mark
Is the fan an uprated aux fan?
Nope its a 20" Proper fan with the Shroud to make it work right
i will keep the ac fan too as i have a twin electric control unit
You are going about building this zx the right way.....what you have just bought in my currency here in South Africa is equivalent to the cost of a new small city car....I would prefer the zed parts!!!!!
I just ejaculated.
Well now put the cat outside and just carry on as normal...
I just ejaculated.
  • 3 weeks later...
engine block and crack is bk from the machine shop :)
Time to start building the engine
The Build has Started
more pics
Wow!
Please keep the photo's coming Mark.
This will be the closest I will ever get to doing this myself.
Very envious indeed. (in a good way.)
Looks cool Mark,
Are you using TT oil squirters or NA? I've read about the NA being better if using aftermarket pistons not sure if there is any validity to the claims.
That guy looks like he's getting a bit excited over your empty engine bay in pic 9
And he's wearing some very attractive pink slippers :)
Wow!
will keep them coming
Looks cool Mark,
Yep NA Oil Squirter's is a Must with After Market pistons
That is my Lad being nosey
Hi Mark, I am about to embark on a similar build but I am dreading the piston ring gapping process. How easy/difficult is it to ensure that the ring ends remain square after grinding? Is a dremel tool up to the job? Anyways great build this is and I will be following this one for sure. Keep em pics coming. :thumbup1:
