Been saving up for my next engine upgrade
Going to be Proper Power now :)
Emerald After Market ECU ( Got )
90mm Wiseco pistons $750
90mm Cometic HG $166
JWT 500's Cams $920
BDE VTC Pulley $445
BDE EX Pulley $365
2.5" inter cooler pipe set *
Side Mount Inter cooler's * $1500
Larger throttle body's *
Clear timing belt covers $195
Surcharge $150
Postal $245
Total $4736 = £2928.69 A fooking lot
plus import duty's
Plus another £200 quid for Engine work
Is any other person needing items from cpz in a few weeks time ?
Edited by MarkDerby
  • Replies 298
  • Views 12.1k
th400 gearbox that`s what you need :)
That is one of the options that has been bounded about but not what I'm going for :)
funny thats all most the same as what cpz said about them
he recommended the GTX range due to having a Billit alloy comp so spoooooooooooling time was less
Just going on my experiance on a 1.8 don't get me wrong keep it spooled and there great but if you miss a gear or get caught in to higher gear and there very laggy,
But god it was quick
yeah but in the real world ... your not driving your car in the 4.5k rev band .. do that in first and your all ready breaking the speed limit :)
but in the real world you don`t need this kind of power :)
with the right package it wont be laggy at all,large downpipes plus a 3" exhaust,suitable cams,bigger intercoolers and piping it wil still have loads of power off boost.Jaffas car spools like a bitch with 3071,s and has minamal lag and loads of power off boost.
Might as well get the 2.5" intercooler/piping/throttle body setup
Nice spec list going on there, going to be a beast!
Ya slow its on the list lol
why whats the difference ? and thats for the heads up
The first ones have build quality issues
ok but i can not find any info on this and both cpz/z1 dont list the ones they have as rev2 or 1
all new ones will be rev 2, just make sure Coz hasn't got old stock
These are the revised ones:
http://www.z1motorsports.com/product_info.php?cPath=6_7&products_id=1911
Their announcement:
http://www.twinturbo.net/nissan/300zx/forums/general/view/2488772/Z1-Motorsports-58mm-CNC-Throttle-Bodies-V2-now-available.html
First versions were poorly made with butterfly sealing and shaft blow by amongst other manufacturing
defects. Lots of complaints. Just let CZP know that you are aware of the issue. Z1 didn't replace the first
versions shipped to customers, so there may be some still around with distributors.
-Andrew
Kinda had to revise my order ..
More items needed due to upgrading other Items :(
Intercooler Pipes $500.00 £309.19
Intercoolers $600.00 £371.03
Throttle bodys $400.00 £247.35
Cam Covers clear $195.00 £120.58
JWT 500 Cams $920.00 £568.91
JWT Heavy Duty Valve Spring $324.00 £200.38
BDE VTC Pulleys $445.00 £275.18
BDE Exh pulleys $365.00 £225.71
89/90mm Wiseco pistons $750.00 £463.79
89/90mm 053 Cometic gasket $150.00 £92.75
Heavy Duty Clutch Fork Kit w $79.99 £49.47
Fan & Shroud Kit $185.00 £114.25
Surcharge $150.00 £92.75
Postal $245.00 £151.50
Sub Total Amount $5,308.99 £3,282.84
Garrett GTX 2863r $2,963.00 £1,832.29
Total Cost $8,271.99 £5,115.13
Eceddy Hyper twin place clutch £500
i can not believe how much things mount up
Edited by MarkDerby
Jesus....plus the un-seen and the car purchase..thats one expensive zed. Nice spec thou and look forward to the biuld thread:drool:
