If i buy a front set of skyline r33 gtr brembo brakes will i have to change the back or can i leave them for now? caz they lock up loverly with my handbrake and i wont have funds for a while but can i get away with this?:punk:
I have brembos on the front and standard at the rear which work fine
that might be the case but the rear on my car are just the way i like it. and if i can sort the front out then im well sorted
I have them up front with stock rears as well
na got to be wrong somewhere ant it , to good to be true, advert said two caliper brakets not calipers or am i being pesamist?
You buy the kit which is.......................................
The kit will consist of:-
2 x 345mm Brake Grooved Discs
2 x HEL Brake Lines
2 x Brackets
4 x Caliper Offset Spacers
Fitting bolts and instructions
then buy two calipers.
Job done
whitch cost upwards of 300 for second hand ones plus that ill be better of with new . ant got 600 quid to spend on some brakes
nope they will cost you around 200 maybe less if your good at looking. also they are newer and even bigger, the problem with gtr calipers is the fact they are now getting on, most sets with teh dics are now going to set you back 400 maybe its alot of cash for 15+ year old calipers.
