LED Dash lighting question
- Replies 28
- Views 1.1k
- Created
- Last Reply
groover 7 posts
tornoutlaw 5 posts
phutumsch 3 posts
vodkashots 2 posts
Evening guys
Seen as my car is off the road till I replace the broken ignition barrel, and I've had to pull apart the dashboard, I've decided to replace the lights in the control pods with red LEDs. Everything seems to work as far as I can tell, but the lights are really really dim, and I'm starting to think I've made a mistake with either my LED's or my resistors. I'm hoping someone can help.
I was under the impression from reading the guides in the FAQ section that I needed 5mm LED's and some 470 Ohm resistors. The resistors and LED's came from Maplins. The resistors I'm using have the colours yellow violet red on them. The packaging says 1/4 W 5%. The LED's have no markings on them.
When I attach them without the resistor they light up really brightly, but get pretty warm so I guess they wouldn't be safe like that.
As you can no doubt tell electronics isn't my strong suite!
Any help would be great.
John
