Hi, quick question. Is there any easy way of telling if my zed has a chipped ECU? previous owner thought it may have been done but im not sure.
The quickest would be to connect to conzult or datascan. Failing that if you whip the lid off the ECU and you see a chip sitting in a socket then it's a good bet that it is chipped. The factory chip was soldered directly to the pcb.
If it has been chipped, it's always a good idea to find out what tune the chip has been programmed with.
