seen these come on over the last year
one of the works small'st PC @ £30 quid
do u think it would work on carputer
The Raspberry Pi is a credit-card sized computer board that plugs into a TV or Monitor.
A miniature ARM-based PC which can be used for spreadsheets, word-processing, games, high-definition video and more.
Broadcom BCM2835 700MHz ARM1176JZFS processor with FPU and Videocore 4 GPU
GPU provides Open GL ES 2.0, hardware-accelerated OpenVG
1080p30 H.264 high-profile decode
GPU is capable of 1Gpixel/s, 1.5Gtexel/s or 24GFLOPs
512MB RAM
Powered from micro USB socket
Boots from SD card
Size - 85.6 x 53.98 x 17mm
HDMI socket
USB 2.0 socket
RCA video socket
SD card socket
10/100 BaseT Ethernet socket
3.5mm audio out jack
Header footprint for camera connection
http://www.hotukdeals.com/deals/raspberry-pi-model-b-now-with-512mb-ram-cpc-29-95-delivered-1336352?utm_source=Facebook&utm_medium=Wallpost&utm_content=deal&utm_campaign=Social%2BPosting
It could be used to run a car pc but it would struggle to run software such as centrafuse etc. The biggest downfalls I can see is the lack of sata ports for hdd expansion, the audio output quality will be pants without a decent sound card and the lack of extra USB connectivity. In my carpc I have 11 peripherals connected via USB and a few of them throw a paddy if being connected through a hub. You can get a decent m-atx based carpc for that which will do everything you need and more without taking masses of space.
