Anyone good with EBC's?
Installed myself Blitz SBC ID. Yey.
But not sure what settings to use etc. Anyone? (in simple language please)...
  • Replies 28
  • Views 1.9k
Boost warning on
Boost Limit on
Boost Max Limit PSI 16>17psi assuming that is your Max over all psi and Fuel Map Set up
Boost Max cut 50%
Boost percentage u dial up or down to get the desired Boost level
Boost Gain is how Fast the response is Higher the percentage will give u more a Kick
Boost Settings Per Ch
Set it to Manual
Set Desired Boost Percentage
Set Desired Boost Gain
Ch 1 ( WET ) about 9psi
boost 10%
Gain 5%
Ch 2 ( Every Day ) about 12psi
Boost 15%
Gain 10%
Ch 3
Boost 20%
Gain 15% ( Fun Time ) about 15psi
Ch 4 Up to you
this settings i gave you are Not Spot on but more of a guide :)
Much appreciated Mark! Will give it a go. Thank you
Mark, i cannot see any percentage.. Shall i just put 10 in Gain? Also i dont see Boost..
Also, i think i am running too rich on petrol.. How to adjust it?
Main Display should look like this
Set up the Warning and Safty Mode Max Boost about 1 psi over your max defined boost Limiter to 50
General settings of the controller ... Auto Peak ON / Wast gate mode to AC / Unit Reading PSI
then go to Each of your Ch1/2/3 and set the desired Boost/Gain Levels ( remember these are only Guess Settings )
each car, turbos & set up may be different
boost 10%
Gain 5%
Boost 15%
Gain 10%
Ch 3
Boost 20%
  • 2 months later...
not sure about these pics mark
im confused as you have channel 1 @
boost 10%
Gain 5%
but the picture shows
boost 40
gain 25
graph scale 30
im just not getting it? are the pictures relevant to the settings you have posted above each pic.
not that relevant m8 think at the time of the pics i was messing with the EBC and my Boost Problem
didn't realize i posted pics with wrong values as well
long as u follow the Input values i posted with a few tweaks to suit your car u be fine
Edited by MarkDerby
Righto, i have mine up and running now and have it set to the settings you recommended, but i have no boost gauge to compaire against. It didnt seem to be running full boost (9psi)
These tt's are all new to me so im sort of in the dark about all this stuff.
I tried to fit the 6mm vac lines to the actuators but they were loose as hell and didnt want to tighten up properly so used the 4mm vac lines as they pushed on a treat. Would that be affecting it at all?
yeah it will have a little affect on it .. but i would say slightly high boost level at Set preset .. but this is different for every car anyways so dosnt matter to much long as it does control the boost all is good
if you have tuning chip .. u can crank the boost to 12psi and be safe
right i took mine out today,
boost set at 15
gain 5
according to the blitz ebc it peaked at 5.13 !!
whats going on, no error codes on ecu
If your on stock turbos, injectors and Intercoolers but have an aftermarket chip and the usual breathing mods then stick to a 14psi limit, unless your monitoring Air/Fuel ratio and have a good ear for pre-detonation.
Every car will differ, you cant rely on another settings. You can get close, but you can just as easily over boost and do damage with somebody else's settings. Also, judging by a lot of the settings posted on here over the years (not necessarily in this thread, I haven't checked) a lot of people are running very poorly done setups.
Far better to set it up yourself. Its simple to do and will mean you have a better understanding of how to use it :
Guidelines for EBC setup I wrote a while back :
Every EBC differs in some of its setup, menu options and even terminology , but they essentially work the same way as each other.
SET = The desired boost setting (as a percentage 0-100% (OFF to MAX Boost available).
GAIN = Boost response/consistency. Too low will mean its slow to boost and boost may fall of at higher rpm and too high will cause spiking.
SET GAIN = Is the lowest pressure that the EBC will wait for before building boost. You want this to be around 3psi less than the boost setting your after.
WARNING = the Max boost you do not want to exceed.
LIMITER = the the percentage boost that the EBC will limit boost to if the Warning is exceeded. Should be about 5% less than the SET number.
  • First change it from Kpa to PSI according to instructions.
  • Set WARNING to your desired boost pressure plus 1 psi *
  • Put the SET Boost on around 30% , and leave the GAIN at 0
  • Put the SET GAIN on 3psi less than your desired setting (so i you want 14.0 psi then put it on 11.0 psi). *
  • Take it up the road and in 3rd gear see what boost your getting. Increase the SET Boost by around 5% till you get the desired boost.
  • Then you want to increase the GAIN, start at 5 and go up in 5's. You want to find the point where it starts to spike and then turn it down a little. You should'nt need to go over 20. You may have to reduce the SET a little as you increase the GAIN, just keep an eye on what is happening.
  • Once your getting the correct boost with no spiking you can put LIMITER on around 5% less than what you have set the SET to
Edited by Yowser
No 5.13 on the blitz sbc so thats a ratio isnt it.
No its not ..
the only thing that reads in a % ratio is the Boost amount & Gain with in the channel setting
All other Boost limit and Display is in PSI if thats the Pressure unit u set it to
so having your boost % at say 20% May give u around 9psi ...
right i will give that a go tomorrow thanks
i will report back what readings i get
  • 1 month later...
Right update from recent testing
Checked for boost leak, found 2 the system now holds psi
Settings
channel 1 38% boost ratio gain 8 gives 9 psi boost
Channel 2 47% boost ratio gain 8 gives 10.7 psi boost
Settings
where was your boos leaks ?
Upper passenger side throttle body pipe, I have the mikalor t bolt clamps and it seems they are too wide to sit properly on the throttle body,
Also at the boost solenoid itself I had used a jubalee clip instead of a fuel pipe clip and it ovaled the pipe causing a leak
Tut Tut Gary...jubilee clamps are just not good enough on anything 15mm and under,they will not clamp evenly 360 degree. Glad you got it sorted mate anyway
i know ! naughty me but it never boosted right when i first bought it so thought the problem lied elsewhere.
took it out again today and had it to 11.5 psi. wow this car goes well now!!!!!!
took it out again today and had it to 11.5 psi. wow this car goes well now!!!!!![/QUOTE]
Any zed is a nice car on its own merits but the comparison in power from an NA to a TT with a slight boost increase is another planet and ime sure you,ll agree Gary
lol when your doing 60mph and it steps out at 11psi its defiantly running right hahaha bit of a moment hey gaz lol
Yup that deffinatly was a sphincter clenching moment lol, your a bad influence Steve!
