hid's
Quick question. what bulb is used in our zeds? i'm pretty sure its a h3 fitment but i've seen some kits on fleabay for the 300zx with a h1 fitment.
Can anyone shed some light on this for me please.
Main beam (high beam) are generally only used by people to flash other people....
HID's don't like being flashed, shortens their life. (not to mention the dispersion pater, as there is no projector lens, not that it matter much for high beam)
So not really economical but no one is stopping you if you want to used them, but remember you will have two extra ballasts to hide / put somewhere.
If you want High beams that batch the low/dipped beam colour there are bulbs available that look more like them.
I've just bought some more from this seller as I am prepping some headlights on the bench and fitting some halos whilst I am at it :biggrin:
http://www.ebay.co.uk/itm/160811439573?var=460075213522&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_6427wt_852
I happen to think the 50w halogen bulbs in the main beam work very well and project the light much further than my HID dipped, of course as Gerry as said if you had H1 HID's here when you flash from cold you would only get a girly bit of a flicker :glare:
Just fitted mine this week, nice slim ballast so easy to get in.
Found it much easier to just unbolt the headlight unit to get to the bulbs.
http://www.ebay.co.uk/itm/160811385227?var=460075187080&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Try this link, same seller but in ozzy dollars works out about £2 cheaper, every little helps and all that!
Edited by Cyberbean
Yes but it says not available to the UK :biggrin:
I have liaised with this seller via private email and always get a prompt, polite, no quibble response :clap:
  • 1 month later...
How did u find these .. nice and bright ? and how long was the delivery from them ?
Nice and bright in my garage!!!!....I never fit the headlights to the Zed Mark....sold them to dicky96 last night.
No reason though why they wouldn't be as you say, Cyberbean as fit his perhaps he'll come on.
Dispatch is quick, like anything though from the far east can be anything from 5 days to 25, usually in my experience take about 10, 12 days :cool3:
i have Hid's but they started to play up .. flickering and now one like out completely
I just typed in h3 hid kit bought a set around £30 that was nearly a year ago worked perfect
much brighter and no problems.
if they last a yr I'd be happy to buy another set. but they show no signs of giving up yet.
see if I can find the ones I bought and post up.
the ones on the car now are like 10>13 years old ... so think they lasted the time
just typed in (h3 hid kit) went down a few and hid kit 300zx is in the listing.
less then £30 delivered 6000k and work fine on mine.
I think they are excellent and the ballast is nice and small. They are the only HIDs I have ever used so nothing to compare them to apart from the standard Zed lights.
Also the instruction book is in amazing Japlish and is good for a laugh!
