does any one know the pin is for the green wire saying in the manual for IGN
Would that be Pin 45
RPM is Taco pin 7
is this right ?
i have it wired up light is flashing but nothing more
Red + Pin 49
Bk - Pin 50
Yellow RPM Pin 7
Green IGN Pin 45
White Handbrake
fare as i'm aware this is correct
can any one help ?
When I fitted mine to my 200 I had to swap the green and yellow wires around try that I'm sure it's works as it does on the 200 and Rb engines
Ok Sorted it ....
got the wires mixed up miscounted them
Red + Pin 49
Bk - Pin 50
Yellow Cas Ref Pin 41
Green Cas Pos Pin 42
White Handbrake
Just uploading video :)
all it does it cut the spark fuel still flows and it ignites in the exhaust system to make the pop pop bang bang ...
if you turn the gain up .. IE faster misfire it doesn't do it thats where the Launch/max comes in
As mark said its just cutting the ignition, its actually for track cars esp drift cars better. Stops them running lean when bouncing off the limiter.
