Will this oil filter sandwich plate fit???
i would always recommend a greddy sandwich plate if you can find one.
dan.:biggrin:
Cheers Dave ordered the second one.. Any particular reason why you said that?
Couldnt justify £80 for the Greddy one...
Basically because it says Greddy on it!
2nd one for sure .. same one as i'm using :)
Phew... I can relax now.... :laugh: if it comes quickly Ill get it fitted before JAE....
Have to ask Mark cos I am useless but learning..
Took me about 3 hours today just to get all the cables routed into position for the oil pressure, water temp and boost gauges..
Did use different colours though to make identification easy later down the line and bound them all together in black tape so hidden in the engine..
Pretty pleased with myself knowing how useless I am..
Fitting the the 3 pod gauge holder tomorrow..
Would still be out there but its my wedding anniversary so had to spend some time with the Missus... :laugh:
If anyone needs another the same as the second picture, I may have one but will have to check if my mate still has it.
you need a socket think its 24mm in size to do up the gender change adapter .. and with the sensor blanking bolts and sensors your fitting make sure u use some PTFE tape on the threads this will stop the oil seeping
most of the gauges your going to use will all have different plugs on
Oil/water Temps is 2 3.5mm bullet plugs
Oil Pressure is normally Socket plug
make sure all wires are tide up nice and away from the Steering UJ joint as it sits very close to it
the cables in the end.. took the battery out, glovebox off and was able to feed the cables through the door gromit straight into the engine beside the battery..
Boost cable has gone along the windscreen cowel so well hidden..
running the others keeping them away from the fans and the heat sources is proving a little more of a test..
Usually use a bit of ptfe so good to know thats right...
the vac pipes are larger than the pipe fitments already there.. wheres the best place to buy a reducer..
Tried tightening it on but no good you could hear the air escaping..
