September 3, 200224 yr my clutch is gone so ive got to get a new clutch so im going for a performance one but is it worth fitting a lightweight flywheel and if so do i go for a super lightweight or just a lightweight one? thanks guys Paul ------------------
September 3, 200224 yr hi, lightweight flywheels are good but it depends on what kind of driveing you do,, i list pro's and con's so you can make up your own mind! pro's improved acceleration improved gearchanges(as the revs are easier to control) improved engine braking con's jerky ride due to sensetive throttle worse fuel economy lumpy tickover seems to loose momentum very easly on hills(need to accerate noticebly to mantain speed) engine easier to bog down from lights clutch's don't last as long (as you have to slip it more to get the car moving) --hth-- --neil--
September 3, 200224 yr but it does make a big difference 0-60 in around 4.6/5.0secs just with the flywheel alone!!!!
September 3, 200224 yr now why did you have to go and say that now its not a stock one lol thanks neil
September 4, 200224 yr Semco which clutch are you going for? ------------------ Z first and anything else is secondary! John Newcomb (NukeEm) www.geocities.com/jn300zxtt
September 4, 200224 yr hi i am thinking of going for this one UAS Modified sports clutch with 40% increased clamping pressure and 6 finger cinted bronze (Ceremetalic) button clutch plate. Grips well lasts a long time and not savage on take up. Supplied with new thrust bearing. Anti Burst Casting (Nodular Iron) pressure plate. from www.300zx.com.au it works out at £262 plus shipping thanks Paul
September 7, 200224 yr errr might have to disagree my mates got a lightened flywheel in his car, and his onboard mpg calculator thingy has registered an increase in miles to the gallon, not reduction as stated above
thanks guys
Paul
