Warning e-bay camber kit issue
Ok to anyone who has recently purchased a rear camber correction kit pictured below on E-bay and have it fitted need to urgently check the fixing bolts that were supplied with the kit. There is a problem, I have made the seller aware of but as of yet had no reply, the bolt grade is possibly incorrect, this has the potential for early bolt failure, we have evidence of this and would like to just make every one aware, sure the supplier will be just as concerned ( hopefully ) will be contacting them again tomorrow and will update on their reply.
Jeff TT
Did it fail when fitting it as opposed to failing when the car was in use ?
Whilst been torqued up.
Jeff TT
I hate it when you get a warning but no name of who to keep away from. I feel it makes it a little pointless as anyone could use a similar picture
Membership No 0780
INSURANCE GOOFA
That's fair enough but someone could be buying them now. If you were busy buying them you'd thanks him for warning you before hand right?
Jeff hasn't said anything disrespectful about the guy or anything so I don't see why he hasn't been named.
Membership No 0780
INSURANCE GOOFA
