Hello , new to this
Great forum , interesting ,some nice looking cars .i have a colbolt green standard n/a but just fitted a mongoose cat back sounds good . Owned the car 7 years no problems . Only flashing airbag light for about a year , been to two Nissan dealers with no luck .need some help from people who know these cars.where is airbag computer .the only manual with airbags I've found is lhd and shows next to steering collume . But I've looked every where and cant find. Please any ideas
Welcome to the club mate!!
You have come to the right place; although I don't know the answer to your question no doubt someone will be along soon who does. If not you could do a lot worse than contact JeffTT at Zedworld - he's a 300zx guru and can help with most technical issues!
Richard:thumbup1:
Not sure if this applys to UK / jap cars but got this from tt.net
Because both the search results and the FSM instructions on how to do this aren't exactly clear, here's something that I hope is easier to understand.
If your airbag light flashes after 7 secs, then you need to run the airbag diagnostic codes, if your airbag light does not shut off after 7 secs then the airbag ECM needs to be replaced. To run the codes you must enter the first diagnostic mode, from there you can read the number of light flashed to see what the problem is. The second diagnostic mode is meant to show what codes have been cleared, and is not useful for diagnosing problem.
There are 3 modes for the airbag ECM diagnostic unit:
User (Normal)
Present (Diagnostic Mode 1)
Initial (Diagnostic Mode 2)
User (Normal):
This is the mode your car is in when it is not in diagnostic mode, it needs to be left in this mode for proper use of the SRS system, be sure to return the ECM to this mode after completing diagnostics.
Present (Diagnostic Mode 1):
This mode will display the codes causing the error in the SRS system, the number of short flashes of the airbag light corresponds to the error code.
Initial (Diagnostic Mode 2):
This mode is only useful to see what codes have been cleared, it will also show what code is causing the problem.
Most people, if ever, will only need to enter mode 1, follow the instructions below, simply ignoring the mode 2 instructions.
To enter Diagnostic Mode 1 you will need to activate the drivers side door switch(located in the door jamb near the latch striker) at least 5 times within 7 seconds after the ignition is turn to on.
To enter Diagnostic Mode 2 you will need to turn the key off then back to on, then activate the drivers side door switch once AFTER the ignition has been turned on for 7 secs.
To exit Diagnostic Mode 2 you will need to turn the key off then back to on, then activate the drivers side door switch once AFTER the ignition has been turned on for 7 secs.
To exit Diagnostic Mode 1 you will need to turn the key off then back to on, then activate the drivers side door switch(located in the door jamb near the latch striker) at least 5 times within 7 seconds after the ignition is turn to on.
Now for a visual adaptation from the FSM
Before switching between the modes shown above remember to turn the key off then on, otherwise the system cannot accept the door switch inputs.
After switching to mode 1 the "Airbag" light will flash once long, indicating the code series is about to start, the following number of short flashes is the number of the code causing the error in the SRS system. If the airbag light flashes on for 2 secs and off for 3 secs then that indicates no problem, or an intermittent problem.
1- Safing Sensor circuit is out of order.
2- Driver's air bag module circuit is out of order.
3- Tunnel sensor circuit is out of order.
4- Right crash zone sensor circuit is out of order.
5- Left crash zone sensor circuit is out of order.
6- Center crash zone sensor circuit is out of order.
7- Diagnosis unit is out of order.
8- Front Passenger air bag module circuit is out of order.
9- More than 2 parts of the SRS system are out of order.
Chances are if you have a code that its something simple, the most common thing is the spiral cable in the steering column. I had the center and left crash sensors plugged in incorrectly(switched) and I got a code 6.
No I've tried that and can't get a coad just constant flash . Dealer said if horn and indicators work spiral cable unligtly cause.they think because it won't talk to conzult must be airbag computer at fault. So want to remove to get reset hopefully
have you tried the fuse for it? sounds simple but always best to check the fuse, also have you tried the clock fuse, ive read about that as well can effect it.
Yes pulled and checked the lot not easy to understand in Japanese .a 10 amp i think
Have airbag modules in stock, will post a picture up for you to see what it looks like.
Jeff TT
Hi I've seen pictures of them but I can't find it .where is it located
What do you charge for one .have seen reset on eBay £35 but nissan dealers can't talk to it to get a coad.i mite be better to try another one
