injector fault
ok had the RAC out to confirm what i already knew ,,,hes checked all cablse and ohms on the injector and came back 40 kilomes and a good one is 9 or .9 i think he said checked the injector cable and thats pulsing ok ,,,so where can i buy a new injector from??
im thinking of changing it myself its on the left side middle looks like i could grind some of the plenum away to get to the screw head ,anyone done this one before?
Usually when one injector fails, its not long before the rest follow, and they can be a pita its usually best replacing all anyway, z1 would be your best bet. though you could also try zcenter or MJP.
If its a standard injector we have them on the shelf, £35 + VAT tested and warranted.
Jeff TT
Tel: 01675 463134
told you it would be an injector :yes:
I dremel'd my plenum to get to cyl # 4 injector a couple of months back, it took a while but worth it for future maintenance.
Yep i did the same when the front N/S one died , i found a dremel a bit slow so ended up using a carbide burr cutter in a cordless drill , worked a treat , as for the screws holding the injector in , i used a screwdriver with the right size of phillips head and gave them a couple of sharp wacks with a hammer just to help break any corrosion that might be furring the screw up and they undid really easy.
One thing i found really handy was one of these , not only to pick up any bits you might drop but to see what your doing in the tight confines of inbetween the plenum.
http://www.ebay.co.uk/itm/OSRAM-LED-WORK-LIGHT-FLEXI-NECK-2X-MAGNET-NEW-/250878795282?pt=UK_Hand_Tools_Equipment&hash=item3a698a9e12
Once you,ve done your dremeling , make up a small pipe to fit your vacuum and clear out all the swarf before pulling the injector out .HTH
made a start on mine today ground out the plenum and got the screw off no trouble, got the boys at zed world sending me another injector should be here tomorrow ,then comes the fun part of getting the old injector out jamie has said to use a pair of grips and a good hard pull fingers crossed she pops out
And a dab of vasaline to help slip the new one in ! lol , they need a firm push to seat them correctly . :thumbup1:
Yes no problem can confirm it was sent by Royal Mails finest next day ( Saturday delivery)
Jeff TT
