just my luck help needed
week and a half from beaulieu and its all gone pete tong ,,went to go for a drive this evening and sounds like ive got a bank down ,,pulled of coil plugs when running and it points to the left middle ,swopped over coil pack not that changed plug not that seems fuel as the plug was bone dry im thinking injector,, any one think the same of can i try somthing else better still anyone close to andover who knows zeds inside out? dont think im gona get it fixed by the 5th :0(:angry:
If it isnt spark related it points to fuel, either dodgy injector or could be dirty/corroded connector.
can i remove the injector with out taking the plenum off
Yes on most but iirc number no.6 needs a slight mod to the plenum with a dremmel to get it off.
I think you can if you get medieval with a dremel so you can get on the screw heads, otherwise its plenum off I believe.personally I wouldnt fancy the idea of getting loads of fine aluminium dust all over my engine so would pull the plenum and do water pipe bypass at the same time :)
oh sh*t dont think im that clever ?
how long would it take to remove the plenum
I dremel'd my plenum a few months back on cyl # 4, took over an hour just to get to one screw! check the resistance between the pins on the injector in question, and compare it to a couple of others. My faulty one was loads higher.
Depends how good you are with the old spanners and whether water bypass/egr delete has already been done.havent done mine yet (next week all being well), but would have thought 2 to 3hrs.......sure someone will correct me if im a mile out.
you all lost me ,im a driver and know little when it comes to testing leads
anyone know of a place close to me as i would like to sort it by next week?
do you own a multimeter or know someone that does? is dead easy, just unplug the loom from the injector and hold one probe on one pin of the injector, and the other probe on the other pin :)
The meter will read out a resistance - i.e. 0.05 ohms. I think my faulty one was something like 1.36ohms, which is a LOT higher. (trust me) :lol:
as above, firstly if your sure there a spark. fire the car up and let it run, then get a long screw driver and place the shaft on the injector itself you should hear a loud clicking through the screwdriver which should be a uniform noise to all the others.
if its clicking away happy as larry then turn the engine off and pop off the injector plug. you will see inside two little prongs check these are clean, clean with electrical switch cleaner if necessary. once clean, set the multimeter to ohms it looks like a horse shoe. by placing the multimeter on each prong you will get a resistance, it should be 10 to 14 ohms i believe with around 12.4 being stock resistance. if you get a reading out of this range shes fubar! theres plenty of youtube vids to show you aswel. pictures worth a thousand words and all.
cheers mate i will see if i can get a multimeter from work tomorrow and have a try
i cleaned the plugs out had all that green looking powder in there but still no good think the injector has gone
Do the listening with a screwdriver test, very simple and very effective
Also check the connector on the ptu is seated properly
[sIGPIC][/sIGPIC]
