200sx tie rods fitting the 300zx?
they look the same and are half the price? and available off the shelf. im gonna try and compare them upclose to check but atm it looks like they are the same, which also makes them the same as a huge long list of nissans.
yeah thats what i seemed to work out from it, that the arm or tie rod itself varied according to the car which makles sense but nissan had used the same tie rod ends. il take the old one in with me to compare, only way to know i suppose.
unfortunatly they arnt the same, i think it was an s13 i looked at. maybe s14s are different i dont know however, the one i tried was too short, the pinion was the correct size the thread was correct it was just too small via about 2 inches in length.
z32 rod arms are thicker alot of drift guys use z32 arms they are the same a tein uprated arms .S13 arms will fit but are thinner also s13 trackrod ends will on fit on s13 arms .but the inner rack fitting is the same tread .S13 rack gaiter will fit although there a tight ish fit but cheaper than z32 ones and avalible at most motorfactors.
