Guess what .......................Engine out again
it never ends for me ..
looks like a may of blown a piston ...
soo its forged time looks like
but gonna be off the rd for a little time and going to
miss some shows looks like :(
any one got a good bottem end with forged parts they want to sell ?
  • Replies 264
  • Views 10.8k
Just Priced up some parts
Wiseco Pistons & Ring Set......$614.00
Cometic Head Gasket............$190.00
ARP Head/Main Stud Kit.........$274.00
ACL Rod Bearings..................$60
ACL Main Bearings.................$80
Total....................................$1219
Total UK Pounds ....................£770.61
so at a guess engine rebuild for 1100 quid
thats with inports dutys and having the bores done
and Heads skimmed
and Heads skimmed
and the labour ...
and the labour ...
no labour charge as i can rebuild my self ...
just depends on what bore damage but thats costed all ready
what does it cost for a rebuild?? that sound naff all lol!!
would say 2k+ depending on the parts used
its full metal type ... where as normal head gaskets have metal rings but the rest is made from some sort of softer stuff ...
softer stuff being composite :)
anywhere between 2.5k to 15k depending on whats needing to be done and whatm type of parts are used :)
heads skimmed 50-100 for the pair iirc
getting the bore done 140 i saw on another thread.
import tax plus 20% with Z1
Mark when you import give me a shout please i need some ACL bearings for my engine build i think that is all :) cheers
Sorry to hear about your troubles Mark , it, sounds like your going down the right road now though :thumbup1:
it will be next week ....
still need to rip the engine out ...
so if u need something at the same time i need to know
plus £££ needs to be sorted
i'm speaking to ConceptZ tomorrow see what discount i can get and Postal charge
i dont want it sent by ups as it allways ends up getting duty ...
what about the crank ? no polishing or getting the valve faces and seats cut,its not quite so simple,anyone would be a fool to fit new rings and not have the valves looked at.And dont say lap them as id love to see anyone try to lap a 20 year old exhaust valve out of one of these things.
thats something i have thought about .. and will be speaking to a local engine tech place just around the corner from my shop ...
when u say polishing u talking about the crack ... if so all ready thought of that
Trying to pm you but you have exceeded your limit,and yes the crank journals should be polished using emery cloth to remove any imperfections.
will try .. going to see what type of Discount i can get ...
got it all down on paper
i had thought of using them again but i really cant do it. lol. i would rather replace for the sake of 120 than risk using them again and it going wrong. lol
can tell you've had a tax refund mate. You would have used it before cos your a tight arse. :laugh:
Parts, Prices and Job List
Price & Order
87mm Wiseco Pistons ( Size Providing no damage )
Cometic Head Gaskets 051 up to 6thou skimming ( 051 ) is what in MM
ACL Rod Bearings
ACL Main Bearings
VTC Springs
Crank Oil Seals
Engine Gaskets ( excluding Heads )
Ring Comp
Valve Stem Seals ( if needed )
Jobs need doing
Main Block homing or Boring
Heads Skimming & Valve cut
Crank Polishing
Items for Other ppl
Mikey Bean
Wiseco Pistons
Comeic gaskets
EGR Delete
Gonzo
ACL Bearings
Main Studs/bolts really needed ?
Edited by MarkDerby
lmao cheers mate. i want 500bhp and i thinnk i can get there now with my nice bit of cash. lol
Should do matey, but haven't you got auto cams and tubs on your engine?
yeah with my upgrade hoping for 500hp there abouts maybe i'm only 50hp from it
run a diffrent map and little more boost
Are you serious ? do you understand what they do and how they work,they are coated metal layers which when clamped create a seal.its not a gamble i can assure you,i never suggested it for a joke.When you take them off you will see what i mean.On the US forums people have re used them 5 times with no issues.I know of two people personnally running used cometic gaskets with no issues whatsoever.But if you know best........
im not saying i know best mate far from it. its just the fact i cant do it. if i use them again ill be constantly scared of useing my car through fear of it going bang. it shouldent but i will still be scared of it happening. 120 is a small price to pay just so i can sleep at night. you can have my old ones if you want. lol
I'll have them if your giving them away :)
