Guess what .......................Engine out again
it never ends for me ..
looks like a may of blown a piston ...
soo its forged time looks like
but gonna be off the rd for a little time and going to
miss some shows looks like :(
any one got a good bottem end with forged parts they want to sell ?
  • Replies 264
  • Views 12.6k
Spoke to Turbo place and he explained how the oil can end up in the boost lines/exhaust with engine fail ...
he said if a piston had a Hole in it and turbo was on + boost this would pressurize the crank case and push the oil
back in to the turbo from the drain hole so oil is being forced from both ends of the tub so the only place for it to go
is though the shaft oil seal and in to the pipes ..
but hes all so said he would pick up and test and return the tubs for free
so as you can see cylinder 6 has melted and all so looks to be a small gasket leak
on from oil well to 5
sooo whats caused this ?
is it just the Temp of running the engine hard ?
the colour and carbon build up on all of the pistons would say are right ..
the bad piston/cylinder doesn't have scores on it but its transferred alloy from the piston
the ring looks intact but will know more when i strip lower block tomorrow
started at 6pm finished 9:30 taking it from Full engine to bare short block
what AFR were you running on boost?
Also, the oil would have come through the front PCV ports when the crankcase was being pressurised, so hopefully your turbo's are ok
AFR sits around 14>15 .... 16psi
thought about pcv valves but that wouldn't explain oil in the intercooler thats before inlet/pcv ...
no wonder it went pop, AFR should be 11-12 on boost
I referring to the ports on the front valve covers, connected to the IC piping
I may be wrong on that I will check tomorrow it could be 13/14 ... So u say its running lean if its not what u said .... So how
To get it to run more rich ?
I agree James,that is a recipie for disaster,no wonder it went bang !! that piston has detonation damage for sure,if left it would have tracked down the side of the piston.The afr is well off.
Looks a bit better than mine did when it let go lol sadly nearly all pics of a fecked piston on here are from No.6, obviously on pre 94's.
Decent performing coolers keeping the intake charge temps down, good mapping or chip (such as JD) that runs a little richer when on boost will help prevent this kinda thing.
Bare that in mind when you do the rebuild and add N/A oil squirters too with using forged pistons and jobs a goodun.
Sadly a reflection of a 20 year old plus piston suffering on higher boost and not enough fuel.
smithy
smithy
Just to ask an obvious question that I'm sure everyone knows but me, how come pre 94's suffer from this issue with cylinder 6 but not post 94? What difference is there? I knew the injector rails were different but I thought that was all?
so just checked yes it was 14>15 on the AFR and that being limit of lean should be on around 11>12 like said before
but when i was doing some read ups it said 14>15 was normal for petrol cars ....
anyways so to get the afr right will need a remap right ?
and whats with the NA oil sprays thought the turbo ones was better ?
just found this info from this website
http://rusubaru.com/afrs-101/
AFRs 101
afrAFR stands for Air-to-Fuel Ratio, a mass ratio of air to fuel present during combustion and is measured by an oxygen (O2) sensor. It is extremely important to know what AFRs are and how they are used in tuning, or you will not be able to tune your car.
There are several common fuels used in automotive applications and each fuel has different properties. The properties you should know most about are the stoich value of the fuel mixture and Lambda.
Basically, stoich value is an Air-to-Fuel Ratio at which the given fuel undergoes complete combustion. This value also corresponds to Lambda value of 1.0 (Lambda 1.0 = complete combustion).
For example, gasoline has a stoich value of 14.7:1, this means that when 14.7 units of air get added to one unit of gasoline, that unit of gasoline undergoes complete combustion – when it’s done burning, there is no more gasoline left over. Lambda 1.0 for gasoline means that gasoline underwent complete combustion. Methanol, depending on your source, has a stoich value of 6.4:1 – it burns completely with only 6.4 units of air per unit of methanol.
Below is a table of stoich values for common fuels:
Fuel Stoich
Gasoline 14.7 : 1
Natural gas 17.2 : 1
Propane (LP) 15.5 : 1
Ethanol 9 : 1
Methanol 6.4 : 1
AFR values higher than stoich mean that you have a LEAN mixture, values lower than stoich mean that you have a RICH mixture. For example, for gasoline 16:1 mixture is lean, while 12.5:1 is rich. Leaner mixtures provide more power and hotter temperatures, thus increasing the chances to run into high exhaust gas temperatures (EGT), detonation and engine damage. richer mixtures tend to provide more torque and lower/safer combustion temperatures. Ideally, you want to run as lean as possible without running into high EGTs or detonation. Read more about EGTs
Side Note: At full load on a gasoline forced induction engine (without alcohol injection) an AFR reading of 12.5:1 indicates a leaner mixture, while 10.5:1 indicates a richer mixture. Good AFR for a forced induction engine at full load is 11.8:1.
Any fuel burning at its stoich understandably produces peak power, and generates a lot of heat. More heat than your engine can take at a full load. At full load you have to add more fuel than necessary for complete combustion – the extra fuel goes towards cooling the combustion process.
In forced induction engines under lots of boost and at full load, a lot of extra fuel has to be introduced to effectively cool the combustion process to sustainable temperatures. Exactly how much fuel you need to add for cooling is determined from your AFR readings.
On a forced induction gasoline engine you should be targeting 11.8:1 AFR for good power and efficient cooling. This 11.8:1 AFR corresponds to a Lambda value of 0.8 (think of it as 80%) – and this in turn means that at 11.8:1 AFR, 80% of gasoline undergoes combustion and 20% of the total gasoline injected into the cylinder goes towards cooling the combustion process.
With alcohol injection, you can use alcohol/water mix to replace those 20% of gasoline used for cooling. Alcohol/water is much more efficient at cooling that gasoline. Plus you’ll get a better fuel mileage. Read more about alcohol injection, tuning for alcohol injection and how much alcohol you can inject.
You cannot tune your car without knowing your AFR during the pull at any given point in the RPM range. Stock turbo Subarus come with a narrowband O2 sensor, which is only capable of reading AFRs from about 12.5:1 to about 15:1. In order to be able to tune your car, you will have to install a wideband AFR sensor, that will allow you to read AFRs from about 9:1 to about 25:1. Read more about the proper mod path.
To sum it all up:
AFR is air-to-fuel ratio
stoich value is an AFR at which the fuel burns completely
each type of fuel has a different stoich value
Lambda 1.0 means complete combustion for any given fuel, Lambda 0.8 means 80% fuel goes towards combustion, and 20% goes towards cooling the combustion process
alcohol/water mix injected into the cylinder provides much better cooling than extra gasoline
you must have a wideband oxygen (O2) sensor to be able to tune your car
Edited by MarkDerby
Injectors, fuel rail and lower plenum were changed. It was noticed the No.6 piston did not get quite as much fuel as the others. Nothing drastic that would effect a standard Zed, but once tuning running richer than norm would help compensate it.
N/A oil squirters direct the oil in a different direction to TT ones, given the design of forged piston tops, TT squirters do not direct the oil where needed the most. Again not a die hard thing you must do, but considering cost of parts and prolonging pistons and their performance, it is an ideal thing to do.
JD chips run richer than most when on boost to protect going lean and of course a custom map could be done to be even more accurate, knowing your intake charge temps is a massive bonus when using higher boost though and no using stock coolers with bigger tubs and injectors!
smithy
14.7 is good for NA's (or when turbo cars are idling/crusing)
This is the important bit from your write up
In terms of chip, you need one for aftermarket turbo's that has maps to cover the extra airflow. Remember it's not the boost it measures, but the volume of air
understood .. i been waiting for JD to sort me a chip out ... abit more tailored to my car
but i know hes been away and biz but still waiting
any tips on how to get the Timing Belt Crank Sprocket Gear off ?
all the main crank pully is off doest want to budge
and i dont want to be wedging/prising against the oil pump
I had to grind a slot in mine, then chisel it and crack it, was a nightmare to get off, hope yours isn't like that tho, could try a bit of heat?....
had to cut and chisel it off ... but can swop it with another one ..
oh and i need a new oil pump i kinda damaged it :)
so here are some more piccys
Crank looks spot on No Marks on it what to ever
Beaings are good but worn out 2 are showing some brass
Piston 6 has a nice hole in it
Edited by MarkDerby
List update
87.5mm Wiseco Pistons & eagle Rods.............................................. ..$1098
ARP Head/Main Stud Kit............................................... ....................$265
ACL STD Rod Bearings.......................................... ............................$55
ACL STD Main Bearings.......................................... ..........................$72
VTC Springs........................................... ..............................2x$18=$36
Full Engine Gaskets set inc Oil seals,valve seals and Cometic Head.........$355
Ring Comp.............................................. ........................................$17
PCV Valves............................................ ...............................2x$11=$22
Timing belt sprocket..........................................................................$24
OEM Oil Pump...................................................................................$170.56
NA Oil Jet's............................................................................3x$33..$99.00
Postal $170 with other parts in box
Total .................................................. ............................................$2383.25
Total UK .................................................. .......................................£1518.89
Main Block Rebore..........................................................................£180
Heads Skimming & Valve cut inc fitting all stem seals £100 Per Head = £200
Total Price up to date £ 1898.89
Mikey ( need to know Piston Size size )
Pistons are $595
egr delete $32
bit of p&p & duty if any
Gonzo ( need to know bearing size )
ACL Rod Bearings $55
ACL Main Bearings $72
Mikey, Gonzo i will be about ready to order by the end of the month
Is there anything more i should be thinking about ?
Edited by MarkDerby
Wow cant believe that piston! is the crank cracked too?
Mark you would benefit from a wideband and an Apexi SAFC2 so you can tweak the AFR to your requirements
crank is fine
u got one for sale ?
i have AFR wide band gauge ... but ..... i been reading it wrong :)
Edited by MarkDerby
