before i spend money on new plugs ,can somebody in the know confirm that i should use NGK 11 C for a twin turbo running a max of 15 PSI, also what plug gap should i set,
thanks
Sayers
Yup, NGK PFR6B-11C
No reason why you should have to gap these if new, however you could check all are the same if you really wanted too.
Smithy
Your welcome!
The plugs are pre gapped from the factory so expect pretty much everyone simply fits them.
So maybe best you search the forum for the answer or do as suggested and check the gap in them all which should also give you the answer and you'll be able to post it up....
smithy
1.1mm, hence the 11 in the plug number...
Dohh and drat! :shifty:
smithy
sory to skip in , but neil,if you still have my number could you txt me or sumthing as my old fone died and i lost all my numbers. hope all is well with you :D thanks you again ! btw :D
