January 27, 201214 yr car has been standing for 6mths and went to try to start it and it turns over and runs then cuts out has new fuel quarter of a tank any help is aprecIATED
January 27, 201214 yr you could start with this.... ECU code check... http://www.300zx.co.uk/forums/showthread.php?t=128845&referrerid=16305 the other thing (that's easy) to do is check/clean all the electrical connectors in the engine bay...
January 27, 201214 yr the FAQ storage area is your friend.... http://www.300zx.co.uk/forums/showthread.php?t=79566&referrerid=16305
January 27, 201214 yr Author had new injector connectors done could it be the idle is too low as i had car starting then cutting out and unplugged the sensor and increased the idle speed reconnected the sensor and it was fine after that the mechanic done the work but cant remember where the idle sensor is
January 27, 201214 yr Author this happened last year would start then u would select gear and it would cut out but always started first time
