Getting my arse into gear and looking to start work on the car, looking at these tubs, thoughts?? I'm sure I can make them fit!
Air Inlet 4" Compressed Air Outlet 2.5" Bearing Journal Bearing Turbine Housing Flange Standard T3 Exhaust Outlet 4-bolt, 3" OD HP 300~500 WHP Cooling Oil and Water Cooled Working Pressure 6-25 PSI Compressor .70 A/R Turbine .63 A/R Compressor Wheel 61.3 /82 mm Turbine Wheel 62 /67.8 mm
Be easier if you just provide the link to them mate, but a 4 bolt turbo will fit without probs at all, in fact it's reasonably smallish
smithy
Via email from a supplier with some pictures, I asked for something capable for 600+ and he sent me that- Gt35 turbo
single turbo again? GT35 is capable of that on it's own
obviously much bigger than the standard OEM ones, stock one could probably nearly fit in the inlet of the GT35!
I'm thinking twin tubs :hammer:
Assumed (stupidly) you'd been looking at Zed turbo's and seen the 4 bolt mentioned.
Anyway as your a man that likes a project, fitting these deffo would!!
God luck
smithy
I'd guess they just gave him the wrong turbo assuming he wanted a single :)
They know it's twin this time, last time I had their T78 turbo for single, I did say I wanted 600+ without much strain on the tubs. I didn't want them work flat our to acheive that power, more like a gentle walk!!!
Time to text Jimmer!!!
Didn't someone try and sell a pair of hi spec heads a while ago??
there is a matching pair of zed heads on ebay at the min dnt no if there hi spec
here are the item numbers have a look ? 260921758317 and ive just found another pair item number 230688934436 ;)
yes, me, and they were sold :)
Good to see you back in action Ant! :) I'm definitely going to be wanting a run out once this project has finished :)
what u want to stop for .... it only slows u down lol
There's some mad genetically modified kamikaze sheep down his neck of the woods....I swear the fookers' wait for you to get close and then run straight at you so monster brakes are definately needed
then again with those turbo's he'll be sucking cattle into the intake from 100yds away!
