which pads
as above . the choice of pads is endless nowadays and varies upon how and where you drive your car . mine only gets used on the road , sometimes a little bit quicker than it should be though . im in the process of fitting new discs and upgrading the fronts to 330mm ( drilled front and rear ) and hopefully a set of skyline or 350z brembo calipers although im having a job finding a set at the moment so any offers would be welcome via a pm . so the question is which pads front and rear for everyday road use that work well from cold but arnt going to fade away with a fair bit of heavy breaking thrown in .
cheers guys
front brembo calipers wanted aswell
andy
Ferrodo ds2500 are a very good pad, albeit a bit dusty with some discs.
Top tip! don't buy your discs before your calipers otherwise your stuck with what calipers you need as the discs are not same offsett Skyline to 350Z
smithy
