Well i got z with out cruise controler is it hard to put in. I know where to connect thing under the bonnet but what about electronic thing inside? I got control pad with switches on/off is connected now also i got steering wheel with control switches but how i can connect them. And what else i should donto make it work?
why bother you will never use it. most remove it, i recomissioned mine last year ive used it once to see if it works. taht was when the football was on and everyone was at home. you cant drive along like that in this country becaus eof the way others drive your constantly dropping outta cruise. also it uses more fuel.
Well sometimes i am traveling big distants and is really helpfull. For me there is no other way better than with out. It doesnt weight is just extra function for a car.
I am doing tt conversion my older car had cruise controler but other one no. So i got everything i need but can anyone tell men how to connect wires inside on steering wheel.
N/A dint have cruise controler but does it have wires to light control pad where is on/off botton for cruise control.
you need.....
cruise control ecu
cruise control actuator (the wire under the bonnet that pulls the throttle)
right hand pod with cruise on /off switch
cruise cancel switches from both brake and clutch pedals (this is very important)
cruise control switches from steering wheel (or control stalk if car with airbag steering wheel) if using steering wheel switches and swapping steering wheel it will need the wheel mount with the correct number of wires
you can then splice into some of the existing wiring loom , but will need to run some wires your self (i think from wheel to bonnet)
i've read a write up of how to do it somewhere on the web, have a good search, i dont think it was a uk zed site so probably american or australian
[sIGPIC][/sIGPIC]
you need.....
cruise control ecu
Looks like is a lot work to do.
Where cruise controler ecu is located ?
It is alot electronic things to do I am not sure if i will be able to do:(
