front fogs
hi ive a uk spec zed with the sideloghts in the front is it possible to convert it to jdm spec with the lights in the side and front fogs
Yes an easy conversion, you will need the spots and side indicators from Jap spec, a small amount of cable connector mod is required thats all for the indicators and the fogs can be wired to the rear fog relay on the passenger side inner wing or a seperate switch if you wish.
Jeff TT
Yes, mine is like that.... easy job... (like Jeff said)...
do you have the indicators with the side light (i.e. two bulbs)?
yes front indicators and sidelights 2 separate bulbs
so i assume you also have the fog lights with the side lights in them.....
just connect/link the side light wires... I think you need to get the right connectors (for either the fogs or the indicators unit) depending on which way you are doing the connection.... but that will become clear as you do the job.
just post a pic and I'm sure someone will have something you can use....
mine is a Jap spec and I had to change the indicator harness... (if i remember correctly..lol)
