How difficult is it to change the speedo face on a zed?
Anyone got a tech with pics for it?
Thanx
it's pretty easy, just take your time...especially when taking the needle off.
-remove cluster from car --> http://300zx-twinturbo.com/tech/meterunit/cluster.htm
-remove two small srews on the bottom of the cluster.
-open up the cluster, it's held together with a few (selffixing) 'clips'
-remove the speedo part from the cluster (4 small screws for the speedo, 4 small screws for the boostgauge and sometimes there's another screw on the top of the speedo.
-remove the small needle-stopper from the face (carefully, it's very fragile)
-now you can turn the needle almost 360 degrees...remember it's lowest point !!
-now turn/screw the needle anti-clockwise while gently pulling it..it will pop off.
-remove the face (it's taped/glued)
-put new face on
-put needle back on, make sure the lowest point of the needle is at the same spot as before.
-put needle-stopper back
-etc..
