Top end tapping
Hi, my engine on my N/A Zx has started making a light knock/ tapping sound. The sound is coming from the top passenger side of the engine under the plastic cover. Taps at tickover then goes when the engine is reved and returns for a moment when tickover returns. There is no noise at all during driving and doesnt effect performance in anyway. VVT springs has been a suggestion? how do i check these.
most proberly your lifter. Mine does it when its stood for a while. really annoying
Try changing you oil. usually works.
if you are using 10w40 oil try using a 5w40 or 5w50, should cure it.
