ere is the recent tech day I organised this month. We ended up with around 8 - 10 Zs for the day and everyone enjoyed getting together after a long break between events.
The plan for the day was to take the plenum off, to check for an oil leak I had developed at the back of the engine and also check one of the heater hard pipes in the same area for coolant leaks. I know Bryan (my mechanic) probably hated me for asking this but I made an extra request for a EGR removal while the plenum was off and to my surprise, Bryan accepted the challenge without hesitation. Upon removal of the plenum we discovered the cause of the oil leak, which was coming from the rocker covers as they weren't screwed down tight enough. Easy fix. Then we checked all the injector connectors and found a ton of corrosion in every one of them as well as every injector. But luckily for me all the connectors were getting destroyed during the removal process and Bryan had brand new snap on connectors to replace them.
My favourite of the day Sam's (sbug88) 91 JDM Slicktop
http://www.aus300zx.com/forum/showthread.php?p=1206004#post1206004
