got me Brembo's think originally off R33, but once i started to clean them up came across some problems so thought ask all the questions before i go any further.
1. As you can see from the pics the dust seals are cracked/split so where can i get a seal kit to service them and is there a how to so i can do it myself?
2. The front brake disc's look pretty shot and i think i read the minimum thickness for changing them is 28mm both are around 24.46mm! so i need a pair of fronts which i think are 324x30x54? the rears are around 20.73mm dont know what they should be!
They bolted straight off a Z without any adaptors so pretty straight forward to put back on, i am going to paint them and from reading old posts Hammerite does the job and with some decals should be good as new.
dan.:biggrin:
Edited by dannzx
  • Replies 31
  • Views 1.6k
Dan, I've ordered from http://www.biggred.co.uk/ , not checked if they do the rebuild kit for your brembo's but I expect so.
thanks Dave might be better to just send the brakes to them and get them to do all the work then, as your a mass of information what about the other stuff brake disc size ect? :biggrin:
dan.:cool3:
phoned http://www.biggred.co.uk/today but they dont touch Brembo brakes anymore too much trouble!:( what they will do is coat them if i strip the calipers down and send them off and also if i send my old seals ect they will try and match them up! what a complete pain in the arse these are turning into!:cursing: does anyone have some info about how to strip down these Brembo Brakes?
dan.:helpsmilie:
I do recall someone on here doing this before mate, pics and details were in his post.
Seach each section of the forum Brembo brakes and you should find it, i think it was about 2 years ago.
smithy
smithy
thanks will have a look.:pint:
dan.:thumbup1:
Look on camskill, under subaru STI caliper or mitsi evo 5>9 caliper rebuild kits. When I looked at this (decided it was more trouble than its worth!) it was difficult and expensive to buy brembo rebuild kits.
thanks will give them a ring and see what they say, looks like to get a rebuild kit for both front's and rear Brembo's sent from U.S.A. is around £60 delivered! i can live with that unless somewhere else does them.
dan.:thumbup1:
found this for future reference may be useful.
R32 T : 280mm x 26mm (single pot sumitomo caliper)
R32 GTS-T (early) : 280mm x 26mm (single pot sumitomo caliper)
R32 GTS-T type m : 280mm x 30mm (4 pot sumitomo caliper)
R32 GTR : 296mm x 32mm (4 pot sumitomo caliper)
R32 GTR VSPEC : 324mm x 30mm (4 pot brembo caliper)
R33 GTS-25 : 280mm x 26mm (single pot sumitomo caliper)
R33 GTS-4 : 280mm x 26mm (single pot sumitomo caliper)
R33 GTS-25T : 296mm x 30mm (4 pot sumitomo caliper)
R33 GTR : 324mm x 32mm (4 pot brembo caliper)
R33 GTR VSPEC : 324mm x 30mm (4 pot brembo caliper)
R34 GT : 296mm x 30mm (4 pot sumitomo caliper)
R34 GTT : 310mm x 30mm (4 pot sumitomo caliper)
R34 GTR : 324mm x 32mm (4 pot brembo caliper)
Z33 NA : 324mm x 32mm (4 pot brembo caliper)
Z32 NA : 280mm x 26mm (4 pot sumitomo caliper)
Z32 TT : 280mm x 30mm (4 pot ali sumitomo caliper)
S14, S15 : 280mm x 30mm (4 pot sumitomo caliper)
dan.:biggrin:
there is a company local to me in bridgend called godspeed. ( http://www.godspeedbrakes.co.uk/ ) He has just recondition my friends calipers on his Subaru STI which i belive are the same brakes you have and it cost him £75 per caliper.
thanks thats handy to know.:thumbup1:
found a couple more pics for future reference.
dan.:biggrin:
got me seal kit for brakes and new brembo stickers once painted!:thumbup: just got save up for new disc's now!:wacko:
dan.:biggrin:
Hi Dan
Trying to stop annoying brake squeal (medium braking pressure - soft & hard braking no squeal). I use Porterfield R4-S pads.
I have Brembo R33 fronts but they never came with any pad shims.
I noticed in the diagram you posted that it didn't have any shims for the fronts.
Just wondered if you had any front shims when you bought them?
Have these to try :
http://www.partsforsaabs.com/product_info.php?products_id=3930
Martin
Hi Dan
Have these to try :
Martin
no didnt have any shims for the fronts or rears and as you say the R33manual doesnt show shims on the fronts, thanks for the link may try them if copper grease doesnt work.
dan.:biggrin:
  • 4 weeks later...
finally got round to taking the pistons and seals out today ready for the calipers to be powdercoated!:hyper:
dan.:cool3:
  • 1 month later...
helped out today to get the calipers ready for powdercoating, first two pics are after being dipped into the acid bath to clean off old paint and gunky stuff then washed off and last three pics are after they have been shotblast clean ready to be masked for powdercoat. :clap:
dan.:thumbup1:
Edited by dannzx
For brake discs have a look for a company called mtech, had them on last two track cars and they rock, also they are cheap!
  • 3 months later...
got the new seals fitted finally so now just got to get them fitted.
dan.:cool3:
Very nice Dan....... Did you get the discs and pads?
Alz.
no not had the money at minute to get them but hope to soon.
All finished now waiting for next step! :thumbup:
dan.:cool3:
