drivers electric window
hi drivers electric window has just ceased to work you can hear the motor working in the up position but nothing in the down is it more likely to be the switch or the window motor anyone any ideas please
no you can hear the motor trying to work in the up position by the way the window is in the closed position
cheers would that account for the window only wanting to work 1 way namely up
Usually the symptoms are both directions fail to work, however its possible the track connector solder on another pin has failed so got to be worth a look first, to remove the conrol box there is no need to remove the door panel, just unclip the bottom section in the middle and look up behind the panel and you should be able to see it to pull it down off its bracket.
Good luck with that
Jeff TT
