Strut Braces do these look any good
Them ones. You want a solid one piece unit, with no hinges.
If you want proper functional strut braces, then its going to cost.
These are probably the cheapest proper strut braces you can get :
Strut Bar Tower SET - Powertrix
http://www.powertrix.com/agoracart55/agora.cgi?cart_id=884.15617&product=Z32_300ZX&user4=Suspension
(near bottom of page) They are replica Carbing Braces.
I've got one of those for the front of the car.. tried to put it on the other day (just for show) and it wouldn't fit!!!!
it hits on the fuel pipe on the plenum... you would have to undo the bracket for the fuel pipe, move it and grind off where the bold goes.... even then it would be very close to the engine and most likely knock or rub.....
junk!!!! keep away!!!!
In 'theory', I suppose it would be possible get a hinged one, (that fits), fit it, and TiG weld the hinges, it's only a theory tho, would have to decent quality to start with I suppose...
Seems like a good oppurtunity to put up a link of great stuff from Japan which includes the strut brace and bracket that I have in my Z.
If you do the conversion into GBP it's pricey - nearly 300 :wacko: but it is a solid piece of kit :thumbup:
http://www.z32-zone.com/original_parts/original_parts.htm
Oooooooooooh, if I could understand anything on that page, I'd be making some orders,
