Boost Problem
Hi Z heads!
The Z31 we have here has a VG30DET (Single turbo from a nissan gloria/Leopard) It hasnt drove for the best part of 2 months, stared it up yesterday on the button, took it for a spin and its boosting at just under .5 of a bar, before this it used to boost 1.1/1.2 bar. Any suggestions? Doesnt feel like a boost leak.
LMM Team.
Not sure on 31's mate, maybe some kind of safe mode? The z32 will restrict boost if it detects problems like det etc.
Baring in mind its not the standard engine! Its very similar to the VG30DETT in the Z32
I thought that the Z31 turbo had the VG30DET installed anyway?
EDIT: My mistake, aparently it wasn't.
Edited by Steams
It does have a VG30DET, but not this one? if that makes sense, this engine was only available in japan in the mid to late 90's. Not alot of em around, but alot of parts are interchangable from the Z32
still might be a ECU thing, lemmi go read up on z31's lol
Its not a Z31 engine! lol
ok this might be of some use.
click on thumb nails twice for larger versions (i think lol)
it will still be plugged into a ECU surely
EDIT missed one.
So it's a Gloria VG30DET + Gloria loom + Gloria ECU in a Z31?
Its a Nismo built VG30DET from a Leopard, Impul Racing Ecu with a bigger turbo!
could it be a boost leak?
Yeah, it could, might be worth knocking up a boost leak tester, pressurising the system and listen for leaks, at least you can rule that out then, should be fairly easy to do too....
The engine bay seems to be getting rather hot. Alot hotter than usual.
Has the water pump been changed recently? If not i'd change it, the thermostat and coolant.
Just get on the phone to Mike at MJP as he is the man to answer your question as he now has a z31 from Japan and if he don't know he will find out for you
Not as if you do not know him :whistling:
Completely different animal to the Z32
Mikes Z31 has an RB25 in it! He would more than likely know though
Tried to pm you but you're not subscribed. Best place for Z31 (even Z31 hybrid) help would be ZClub. Post the question and you might get someone who knows the answer coming on the 21st! 300ZX is, as you're finding out, keen to help but the expertise here is Z32 and Z31 is, as Steve says, completely different animal. Not the same car at all. Good luck.
Yeah we know they are a different car, but a VG30DET (Which is whats in our Z) is extremely similar to a VG30DETT because its from the same era. The Z31 VG30ET is very different.
LMM Team
Good point, Ashwood. But I still think Steve's right - Mike F's your man for that. Plus there's a lot of Nissan hybrid knowledge at the ZClub. There's also a specialist forum http://forums.hybridz.org/
HTH - Gio
