stalling problem
hiya all. hears my problem my car runs and drives superb hot or cold.
BUT soon as i use power meaning lights and heaters together the engine cuts out wen i push the cluch can enyone help please.
Have you tried putting the heaters etc on when the car is cold?
yes i have and its fine. its just wen i use 2 or 3 diffrent power sources. mainly at night lights wipers de mister. car drives fine till you depress the cluch the revs just drop to low.
the Idle ajustment unit might not be working properly.
and or check the alternator & battery for correct charge.
could be as simple as cleaning the contact to the battery (but I doubt it..l0l)
iiv had the alternator looked at cus it is nosey but thay said it was fine same gose for the battery. if it was the idle ajustment would it not do it all the time?
get it on conzult.... you could then see what its doing and possible rule out some stuff...
maybe even find the issue...
any members in your area with consult?
if not the cable and fee version is quite cheap on fleabay..... or it's about 120 miles to Zedworld ... but worth the drive....
sounds like your ficd valve has a bad connection,its at the back of the engine on the passenger side,look for a yellow plug at the rear,the ficd is below it,should have a pale blue plug on it,clean the connections,will be quite tricky i will warn you.whats your cars idle speed once warm?
thanks for your help guys il have a good look. o and jimmer this engine youve built seems grate plenty of power and sounds well. its mick who got riped off by zed tech
yes i have mate an thought id have abit of a drag race with my brother in his evo 9 its running 437 bhp on the dyno an he got hafe a cars lenth on me 0 ta 110 then i caught him. so considering im still running a low boost 11.5 psi its quick be turning it up soon and getting it on the dyno. so il let you no
