Datascan and Conzult Settings
After I got my Datascan software and lead I did a search for settings that I could use as a guide to set my engine up, here are the results that I found.
If anyone has anything they would like to add or comment on please feel free to do so. Once these figures are given the ok I would like it to go in the FAQ section.
Paul
Basic Settings for TT.
Idle RPM 750
Closed Throttle Position
TPS 0.44-0.46
Timing set at 15 Deg
IACV-AAC/V 15%
Injector Pulse 2.2 msec
Injector Duty 1.61%
A/F Alpha 109%
Mas Air Flow 1.30v
Water Temp 80 Deg C-84 Deg C
Fuel Temp 25 Deg C-35 Deg C
some additions to your values:
> TPS 0.44-0.46
These values are only valid at idle and and the values are linked.
if the Closed Throttle Position switch is on, the TPS should show between 0.4-0.5volt.
You can reset the closed throttle switch by unplugging the TPS plug for 10 seconds (the oval plug that is on the seperate small cable)
> IACV-AAC/V 15%
> Mas Air Flow 1.30v
+ P/N position switch: ON
these values are valid at idle and the engine should be fully warmed up.
Timing may show 25 BTDC if the P/N position switch is OFF (may be the case for a malfunctioning neutral switch or an auto to manual conversion.)
The airflow is an approximate value, may vary slightly between cars.
> Injector Duty 1.61%
Again, average values for STANDARD injectors (at idle)
> A/F Alpha 109%
again this is an average value and only works if you have fully functional O2-sensors and ideally you want this value to be close to 100%.
any value over or under 100% means the ECU has to compensate with less or extra fuel to get the mixture right.
Extreme compensations (> +/- 15%) usually mean something is wrong with either air (airleaks) or fuel (injectors/fuel pressure)
these values are valid for a warmed up engine.
NB: the fuel temp values are ignored by the ECU for the most part, so not really important in respect to getting the car running better .
another important one is battery voltage: should be between 13.7 and 14.3 Volt (at any rpm)
If the value is off, it may indicate (future) problems with the alternator
-Eric
forgot to mention that the timing should always be verified with a timing light.
Also the later Zeds don't follow the 15 BTDC at idle rule.
They work quite different and use a variable ignition timing system to get better emmission ratios.
Because of this the timing hovers between 5-10BTDC at idle.
Thanks Eric for confirming the settings I posted and adding yours to the mix.
cheers Paul
