few questions relating to my imment lowering of the car, i purchased some lowered and stiffer bilstiens from a club memeber which i will be fitting.
firstly with a lwb and a 20mm rear drop and around 30mm on the front whats likly to hit speedbumps? exhaust midsection looks to be the lowest part.
obviously the underside of the engine should be pretty safe.
secondly. there are some metal plates that sit on top the struts do these sit ontop the strut or ontop the arch? furthermore to this point if i decided the front was a touch too low could a thicker one be used to space it out a little.
thirdly.is there a way to switch the shocks without compltly resetting the alignment? obviously camber etc will be affected to an extent but i dont wanna take it all apart and it be so far out its undriveable before i get it all set up correctly again.
last question, the rac will not tow cars that have been lowered, as this is quite a subtle drop im thinking they may not even notice if worst came to worst. but they are bright yellow, do i paint them black and claim there new but standard, or leave them yellow and dirty and plead ignorance?
