Manual Conv. Busted Auto Radiator
Bit of advise on this one please folks.
Just bought a manual conversion to fit my 1996 TT but the current auto
radiator is busted at the top and is beyond repair, so what's my options ?
Will I now need to replace both the auto radiator and oil cooler ?
Or is the oil cooler just for the auto?
Ill be wanting to get an uprated radiator when I fit the conversion so rather
do that stick in another auto radiator from a breaker.
What's the cleanest route if replacing the autobox and radiators ?
Cheers folks.
Edited by JaiKai
Bit more info for this post, the TT Manual Gearbox, has oil pipes that connected to the underside of the car.
Deff get an A/M radiator, better cooling for ur 300 matey.
Alz.
I can supply u with a polished A/C spec aluminium bracket at a good price..... :sneaky2:
the manual box doesnt use the box cooler. depending on wether its uk spec or jap spec you ill have differnt configurations. japspec its simply a loop through the rad on the right hand side and you stand infront of it, about half way down. uk spec it passes through to under the air filter, where there is a small oil cooler situated. its all upto you matey, if your switching over to the manual box the simply delete it at source, its not required. as alan said go for an aftermarket rad for safety and reliabilty, teh oem one is adequte at best, esp if your running higher boost etc. good luck with it. hopefully you wont end up with what i found, which is taht it was running through the rad and cooler in series, the problem there being the cooler being used was my engine oil cooler. one very well ciooled box, one hella hot engine.
Cheers folks.
The manual gearbox you have must of come from a UK zed if it has oil cooler pipes, UK zeds had a cooler fitted just in front of the rear subframe, no need to worry though simply link the pipes and forget them, no need for it.
As far as the rad is concerned as you needing to replace it anyway then for £140 you may as well go for one of the alloy ones below.
Jeff TT
http://cgi.ebay.co.uk/NISSAN-300ZX-TURBO-HIGH-FLOW-RACING-RADIATOR-/400203465905?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d2dfc44b1
any idea of the quality of these jeff as the japspeed ones seem to be perminatly out of stock, oh and you have pm.
Jeff TT
With a polished bracket to hold it in position.............Perfect....lol.
Alz.
alz whats the deal with you and these brackets lol have you ended up witha bag of 100 or something
Very cheap for club members, very cheap indeed, and free delivery.....
Just want to help out some fellow zedders, thats all....
Alz.
Would you like to me to post a picture and price for members.....
Alz.
Just to confirm things I took a few snaps of whats where in my zed!
Here's the two pipes on the right side, are these the ones going to the autobox?
Also here's another cooler in front of the main radiator; is this the oil cooler ?
Just so it's noted my zeds a jap spec 1996 series 4.
Yes and Yes!:thumbup1:-when you fit the manual box you can pull out all the hoses/piping for the auto cooler and bin em'.use the original engine oil cooler or better still get a bigger one!
Yeh, go on show us the price and pics then!
You've already hijacked this thread !:lol::lol:
Ok, I only have 2 of these and when they are gone, they are gone.......
£35 delivered to club members only.
Alz.
