Tinting rear lights, gloss effect?
Hi,
I've tinted the rear lights on many cars in my life. I remember the first couple of times I ended up with a fairly glossy finish.
The last couple of cars I did (more memorable was my Probe) I ended up with a very dull flat matt finish.
Now maybe tint spray has changed over the years, maybe I've used a cheaper brand or something. Not sure.
I want to do my Zed (just smoked not totally black) but I want a glossy finish.
Any ideas or suggestions how I ensure I end up with a glossy result? The matt or glossy finish seems to be random.
I seem to remember applying clear lacquer in the past, but seem to remember it reacting with the tint. On googling this someone suggested apply this - http://www.allartsupplies.com/item.php?articleId=2438&gclid=CO7U8s3T-6gCFUEa4Qod3EkaSA
Cheers!
I tinted some on a Opel Manta a few years back and used a normal 2 pack laquer with a few drops of black mixed in to give a glossy smoked effect , the light were prepared using grey Scotchbrite and it never came off and looked factory cos they were gloss , the only thing to look out for is not all paint schemes will allow colour to be mixed with laquer , just depends on the brand ,HTH
I used a few tint sprays in my time and the only one that was any good was Savage.
To get the gloss look you should put the final coat on a bit heavier (depending on how many coats you use/how dark you want it.)
It always says on the tin "apply in light coats" but unless you put the final coat on heavily you'll get a matt finish or satin at best. Just don't put it so heavily that you get runs. Its best to spray on a flat surface to avoid getting runs.
Hope this helps :)
Thanks!! Savage it is then!
I probably should take the lights off the car, had considered doing it on the car, but runs are evil things.
I think I'll get some Scotchbrite too, though can't remember it ever coming off in the past.
