I`m gonna do a brake test any ideas?
Just for research purposes, I`m going to attempt a brake test from stock to uprated, only on my vert but it should shed some light on how much better/worse the upgraded set up should be....so at the moment I have good stock brakes on all 4 corners and next week I will have evo8 Brembos with grooved and drilled disc`s on the front and grooved/drilled discs and red stuff pads on the rear stock calipers..Oh, and all new braded hoses too
So my test will involve braking hard from 30 and 50 mph and see how long in seconds it takes to stop and the distance travelled, I would like to do some sort of brake fade test aswell, not sure how to do an accurate test on this without doing a track day, any ideas on more tests i could do whilst im playing?
Daz
Edited by daZvert
  • Replies 56
  • Views 1.3k
I've got a GTech meter that measures 60-0 braking time amongst other things Daz, you are welcome to borrow it if you want for the testing?
oooh, That sounds good Baz, what does it connect to? do I just stick it on my dash? CheerZ:batman:
you took too long to answer. You cant borrow it now :tt2:
It plugs in the fag lighter, you have to set the angle etc to calibrate it but once its done it should help you out ;)
check dis
http://www.google.co.uk/imgres?imgurl=http://www.avenger-valkyrie.org/forsale/gtech.jpg&imgrefurl=http://www.avenger-valkyrie.org/forsale/gtechpro.htm&usg=__2rdu8bak0TV3NFUgfW-tHKrH5I4=&h=322&w=370&sz=11&hl=en&start=1&zoom=1&itbs=1&tbnid=mIom5o_Qwm_y0M:&tbnh=106&tbnw=122&prev=/search%3Fq%3Dgtech%2Bpro%26hl%3Den%26safe%3Doff%26biw%3D1345%26bih%3D599%26gbv%3D2%26tbm%3Disch&ei=2eHSTafCOtSo8AOYvJndCg :clap:
:w00t::dance::dance::dance::dance::w00t:
Send it to me,oh yeh..... but i dont have a FAG lighter... only a cigarette lighter , Fag lighters are what Mikey bean, steams and the rest of you lot have :wink:
Ok I'll send it out.. btw you cant keep it lol :nono:
I`m gonna do a 0-60 in my tt!!!! fook the brake test :tt2:
nay worries Baz, I will look after it :winkiss:
thought you would :winkiss:
just pm me your address as I'm too lazy to find it ;)
